Guest jasp
Ignition Module
Guest jasp
hi guys,
just bought a mint 205 xs today, all going great untill....
engine cut out and would not start again -
checked spark= no spark
and when cranking over on the starter the revcounter stays at 0
is this my ignition module buggered?
if so can anyone tell me the part number and maybe give me a good website to get one off,
cheers :wacko:
p.s is my TDC sensor supposed to be conected to anything
Dan Ingram
I dont think the rev counter works off the ignition module does it?
Guest jasp
ummm not to sure myself mate, i think i remember someone telling me it does but i might be wrong
bren_1.3
no tcd sensor doesnt connect to anything on an xs.
go through the dizzy first, make sure the rotor arm and cap are ok before you look at the ignition amp.
Guest jasp
ok cheers,
looked at the arm and cap arm is fine but i think i could do with a new cap soon.
think i will just have to buy a cap and arm as well as a ignition module to be on the safe side :wacko:
Guest jasp
anybody know how many pins the module has because on gsf they have a option of 5 or 7 pin modules
cheers
t16ryan
Thet are quite common on coil failures too :)
Guest jasp
:( hmm well i think i will just fit a module and see where it goes from there
Guest jasp
if anyone is interested, i changed the ignition module today and she is now right as rain <_<:ph34r:
andychalmers
My module went on my rally XS rally car on stage, engine died instantly, all lights came on dash etc etc. Was weird, changed ignition module and run sweet.
Guest jasp
yeh when mine died i was giving it some smokey and then sudenly revs droped to 0, i thought osh** this will be expensive, new module mine runs sweet again now aswell
