pugbender 0 Posted November 15, 2008 hi, this evening i try to do the 307 hdi big brake conversion on my 205 1.6, but there is a problem: the driveshaft seems to be of a smaller diameter..so my question is: does the 205 1.9 driveshaft are bigger and could i mount them on the zx 16v hub? Share this post Link to post Share on other sites
Alastairh 47 Posted November 15, 2008 1900 drive shafts are thicker yes. Also you can use ZX 16v hubs with these 1900 drive shafts. Al Share this post Link to post Share on other sites
VisaGTi16v 1 Posted November 15, 2008 If you use zx 16v hubs do you get the same issue as 306 ones ie less camber? Share this post Link to post Share on other sites
pugbender 0 Posted November 15, 2008 probably, let's check when it's all mounted Share this post Link to post Share on other sites
