TaffyTim 6 Posted November 15, 2008 Im trying to get the sump off my old lump so i can remove the pts baffle, ive got all the bolts off but the sump is staying in place with all the sealant, whats the bset way to take it off without damaging any surfaces? Share this post Link to post Share on other sites
jord294 94 Posted November 15, 2008 carefully slide a paint scraper in, and gently twist with a clockwise and anti-clockwise action Share this post Link to post Share on other sites
hodgy 0 Posted November 15, 2008 put a block of wood on sump and hit it with a big hammer Share this post Link to post Share on other sites
TaffyTim 6 Posted November 15, 2008 (edited) ok it was stuck on pretty good anyway but i left 2 bolts on Ive now got it off Im not having issues removing the baffled sump. Am i right in thinking that i have to remove the oil pick up? If so then im sure im going to have access issues with one of the 10mm bolts. Ive taken the 4 off the bottom bolts and one pig of a nut that lives right in the heart of the mother. The last nut that i could see seemed to be ok to get to when starting the removal but im sure when its half way out theres going to be no way of getting to the head of the bugger!! am i not thinking about this botl right or is it a sod to get out? Edited November 15, 2008 by TaffyTim Share this post Link to post Share on other sites
Miles 331 1 Cars Posted November 15, 2008 You just undo the oil pump bolt's slide it off the chain (Remove thin spacer first) then take the baffle out, easy as that Share this post Link to post Share on other sites
TaffyTim 6 Posted November 15, 2008 ok sounds aas if im attacking the wrong bit then, ta Share this post Link to post Share on other sites
