M@tt
Vss Vehicle Speed Sensor
M@tt
right almost sorted my turbo wiring, the final bit is the VSS
the XM that the engine came out of had an auto gearbox and it had a 2 pin VSS attached to the gearbox however the VSS module had also been removed before i got it so i just have some chopped wires which i believe went to it. However as i understand it this was simply a signal amplifier and using a 3 pin VSS it doesn't matter that i dont have this.
I've just spent the past couple of hours trawling autodata and old posts and think i know what i'm doing but would appreciate if any one with any experince could double check my findings.
basically the 3 pin plug has a +ve, earth and a signal wire.
i believe the middle wire is the signal wire and this goes to pin 9 of the ECU (according to Autodata CD)
and as far as i can tell pin 1 is +ve and pin 3 is earth
so is it simply a case of connecting these up in that order??
on a few diagrams it looks as though the +ve feed might also come from the ecu as well? almost in a loop as it were (from ecu through sensor back from sensor to ECU)
Edited by M@tt
Ant
This is mine from a 1998 605 Turbo lump, that had a 2 pin connection.
These are the connections on the VSS box connection
Pin 4 ---> 131J goes to pin 11 on ECU
Pin 5 ---> 131? goes to speedo
Pin 6 ---> 52V goes to switched live
Pin 7 ---> 130C - Sensor on Gbox
Pin 8 ---> 129V - Sensor on Gbox
Pin 9 ---> M52V goes to earth
Useful to note though that ECUs must be different depending on year etc. My 131J goes to pin 11 not 9 as in the autodata diagram.
M@tt
just thought i'd post up that i think in fact the 3pin VSS wiring is slightly different to what i posted up above
looking at the 306 wiring diagrams i have which uses a 3 wire VSS the VSS wiring looks like this
and so the pin outs are as follows
Pin 1 = Swithed Live
Pin 2 = Earth
Pin 3 = Signal to ECU
so thats how i wired up, should find out whether its worked properly once i fire it up :lol:
M@tt
excellent that's good to know
cheers
