djinuk
Replacing Arb Bushes
djinuk
I have a knocking when i go over bumps coming from the left front side of my car, ive replaced drop links, wishbones, and top mounts.. since ive chagned all that ive decided i may aswell replace the Arb Bushes, Ive not done these before, is it a big job, and what does it involve. also does anybody reccomend any particular make of supplier or arb bushes. or have a part number for the gsf ones.
swordfish210
EDIT: sorry just awnsered my own question.
It's not a massive job really. I'd get the bushes from Peugeot. To replace them you need to undo the 4 bolts at the back of the subframe and the lower engine mount bolt. Then undo the bush clamp bolts and slide the bushes out from inside the clamps. Slide the new bushes in and tighten everything back up again.
Edited by swordfish210
As said, get the genuine Peugeot ones. They are under £10 for the pair iirc.
Graham.
swordfish210
Graham.
Didn't realise they were that cheap. The ones from the local motor factors are about £18 for the pair. Luckily i'v never had to buy any :blink:
  swordfish210 said:
Didn't realise they were that cheap. The ones from the local motor factors are about £18 for the pair. Luckily i'v never had to buy any :D
Yeah, last time I bought some (had to get two of each) but they weren't as expensive a I expected.
Just checked on Service box;
5094.42 BAR BEARING 3.71 GBP 4.36 GBP 4.36 GBP
5094.43 BAR BEARING 3.85 GBP 4.52 GBP 4.52 GBP
Graham.
