Jer309GTi 3 Posted November 7, 2008 My 405 has been in the garage for 6 months or so, and the brakes were perfect when I put it in there. Nearly everything brake-wise was new, the master cylinder is 2 years old at most. When I took it for a drive the other day, the brake pedal now goes to the floor slowly, though if you pump the pedal it will go hard, just like if the master cylinder seals are shot. Has anyone had this happen to them before? Just seems weird that the brakes were fine when it went in the garage and now they're not Share this post Link to post Share on other sites
Pob 1 Posted November 7, 2008 Jer309GTi said: My 405 has been in the garage for 6 months or so, and the brakes were perfect when I put it in there. Nearly everything brake-wise was new, the master cylinder is 2 years old at most. When I took it for a drive the other day, the brake pedal now goes to the floor slowly, though if you pump the pedal it will go hard, just like if the master cylinder seals are shot. Has anyone had this happen to them before? Just seems weird that the brakes were fine when it went in the garage and now they're not The same thing happend to my 205 when the master cylinder had gone. Dan Share this post Link to post Share on other sites
