nunoserrano 0 Posted November 7, 2008 Hi could some one help me out i have a 2.0 8v turbo engine whith the Mi16v head but im having a problem wen i push hard the engine spits oil true the catch can could some one post the oil pipe rout to a similar engiene ? thanks or could some one explain me way it sptis the oil out thnaks Share this post Link to post Share on other sites
tom_m 0 Posted November 7, 2008 how many miles are on the bottom end? do a leak down test to see if the rings are sealing properly. if they're not you could be pressurising the sump with boost. Share this post Link to post Share on other sites
nunoserrano 0 Posted November 7, 2008 Hi it as full recon engine whit every things new rings etc Share this post Link to post Share on other sites
B1ack_Mi16 67 Posted November 7, 2008 Hi it as full recon engine whit every things new rings etc Do a leakdown test first. When that's said I've heard lots of people having problems with oil spitting on 16v Turbo XU's. You could try to make one or two extra vents for crankcase pressure... Share this post Link to post Share on other sites
rapidcossie 0 Posted November 8, 2008 as said do a PROPER leakage check and if it passes fit a PROPER breather system, not just some crappy catch tank. Share this post Link to post Share on other sites
nunoserrano 0 Posted November 11, 2008 Sorry but how should i do a PROPER leakage check ? Share this post Link to post Share on other sites
rapidcossie 0 Posted November 11, 2008 Sorry but how should i do a PROPER leakage check ? Snap On do a good leakdown tester that uses an airline, its simple to use and you can detect where the leak is coming from(valve seats,bores etc) Share this post Link to post Share on other sites
weejimmy 1 Posted November 12, 2008 or take it to a reputable garage and get them to do it, cant say i know any in portugal of the top of my head. Share this post Link to post Share on other sites
nunoserrano 0 Posted November 12, 2008 Ok i will try do do that thanks and iff some one could give me a oil pipe route for the engine i will apreciate thanks Share this post Link to post Share on other sites
