Kriss
Lack Of Power
Kriss
My gti idle's pretty low (about 700rpm) The problem is at my house, theres a small hill, te fiesta will do it 3rd gear no problems, the gti nearly died in 2nd. From the lower revs it just seems gutless, but higher up, the powers there. My dad has tried messing with the timing and it's advanced a fair bit, but if you retard it, it just die's Tried a new afm and throttle body, but it's just the same. For the past while, i've been thinking about putting on 1.9 ecu, afm, injectors but i dont know if that would run ok?
steve@cornwall
Bet the valve timings a tooth out - seen it lots . does it pink badly when fully advanced? - my guess is it doesn't
Kriss
it doesnt ink at all no
steve@cornwall
Re set valve timing - you won't believe your right foot :wacko:
