monty69
Wide Track 205 Using 306 Front End
monty69
Has anyone on here done a wide track 205 using 306 arms/subframe? Just toyying with few ideas and wondering if anyone has dared extend the strut top mounts if possible? Am i right in thinking a large gain in track width means less body roll/ softer springs can be used?
not 205, but Sandy has used 306 arms on his 309.
Henry Yorke
Chris Penrose has 405 arms and shafts on his 309 to get neg camber / wider track.
The 306 Dimmas adjusted the strut top to offset the strut and get wider track
Sandy
It's a proper mission to get 306 arms where they need to be on the 205/309, I wouldn't do it again!
monty69
Cheers for help guys. Would a 306 subframe bolt on?
felix2566
Henry, do you have any more info on Chris's car, any pictures of what he has done?
tom_m
along with cut and shut extended wishbones
Batfink
Remember the 4wd widetrack 205 turbo that 205parts were building? There are no pictures on the site anymore but that ran a 405 front subframe and gubbins. I dont think it even needed modding to fit. If I was widening my 205 on the cheap i'd buy a complete 405 front end including steering rack and try to bolt the lot up. Doubt that would cost more than £100 - theres always people breaking 405's for parts...
hman205
From memory Michael had to fab some Blocks up to get the rear mountings of the 405 frame to match up with the 205 floorpan I did use to have pic's of this it may have been done to give the transfer box enough room though
Batfink
with a bit of googling I managed to find the direct link on 205parts :D
mi16 turbo 4x4
I would estimate that this project was started 2005 so was on the old forum??
Certainly cant find any record of this build
Edited by Batfink
tom_m
there were posts on this forum, under the username greenmachine iirc
Batfink
indeed i did try a search earlier with his username but I dont think the search can pull up the threads or posts that far back effectively. i wonder if he was one of the original people like me who's account was deleted when there was a problem with the database and had to re-register..
Edited by Batfink
cybernck
there's a dutch 309 4x4 build using 405Mi16x4 complete front and rear suspension :D.
Batfink
link?? did the front subframe just bolt on?
jonnie205
i very very much doubt any 405 stuff will just bolt on
Having both i also doubt it.
cybernck
i've looked for the project topic and couldn't find it anywhere or i found some with broken image links.
i've looked some more now and still no joy.
try contacting "sander_swinkels" on here though :wacko:.
thanks.
