yorkshirekowboy
Mi16 Inlet Manifold Studs Help.
yorkshirekowboy
as above guys, wanting to know the length of bolt i need, also what size threads are they? are they 8mm?
Ryan
According to servcicebox they're 30mm long, 8mm with a 1.25mm thread.
yorkshirekowboy
yeah a saw that, but surly that must be wrong, i wanting to use stainless steel allen heads bolts only for the inlet manifolds. I have juts found an old exhaust stud, which are the same size etc, and according to the calipers they are 20mm long. so i would need a 20mm cap bolt bottom of cap head to the bottom.
GLPoomobile
I can assure you that whilst 20mm will just about be sufficient (providing you are using a standard gasket), it's ridiculously short, and 30mm must be correct.
Some muppet has fitted 20mm ones on mine. When I fitted a 3mm PTFE gasket, they only just nipped up, I mean like 1 or 2 threads worth :o (the fact that I didn't consider that in the first place also makes me a muppet). The 2nd stupid thing was that I didn't stop to measure the bolts on mine and think about what size I ought to replace them with. Instead I waited until I was at work and then asked the question on here, and the answer came back that they were 30mm M8 bolts. Thinking that my current ones were the original ones, I went and ordered some 40mm M8 bolts, and of course they are too long :wacko: . So the point is, it's 30mm you need. And if anyone reading this is thinking of fitting a PTFE gasket, check what bolts you have currently.
DrSarty
30mm sounds right to me too. They don't cost much OE from Pug, and have a reassuringingly good fit.
Very much worth the effort IMHO to take your time and get a proper allen key style tool to do them up, i.e. wobbly joints for sockets etc, as they are a soft metal which easily round/burr.
Don't only note GLP's advice as to what gasket you're using, as you may also need to consider your manifold configuration, i.e. standard, carbs, bodies because 1 or 2 of your inlet manifold bolts may need to be studs with washers and nuts, just to get access to do them up.
Edited by DrSarty
GLPoomobile
Indeed. On my MI the 2 middle top ones are studs and nuts, the rest are cap head bolts.
yorkshirekowboy
thansk guys for all your replys. all i need to do now it buy some stainless steel ones and take out all the studs and nuts which someone put in. mole grips should do it...
DrSarty
No problem.
Perhaps a dumb question, but shouldn't your tag line under your avatar say: 'bi-f***ing-noculars'?
Anal or what?
Edited by DrSarty
