adamc 0 Posted November 4, 2008 This must have been covered before but i cant find it using the search :s My idle is low, about 500-600rpm, i know that you need to set the idle with all the fans, lights etc on. But how do i adjust it, Where is the screw to adjust it? Is it on the afm or throttle body? Share this post Link to post Share on other sites
mattbenselin 0 Posted November 4, 2008 Its on throttle body on the top, flathead screw Share this post Link to post Share on other sites
adamc 0 Posted November 4, 2008 cheers mate, do you screw it in or out to increase the idle? Share this post Link to post Share on other sites
mattbenselin 0 Posted November 4, 2008 Can't remember but start her up, warm her up then give it a twist you'll tell instantly which way is up and down! Share this post Link to post Share on other sites
adamc 0 Posted November 4, 2008 ok thanks, will give it ago tomorrow morning! Share this post Link to post Share on other sites
davepug205 7 Posted November 4, 2008 Take the angled one right out and clean up with a wire brush as they get coked up ( watch the rubber seal), then replace and fully close. then adjust the small one at the back until it idles at 700 then open the angled on until at ticks over at 1000 job done Share this post Link to post Share on other sites
adamc 0 Posted November 4, 2008 ok will give that ago 1st thing tomorrow. Is the other little screw also on the throttle body? Share this post Link to post Share on other sites
davepug205 7 Posted November 4, 2008 ok will give that ago 1st thing tomorrow. Is the other little screw also on the throttle body? yes towards the back on the top its only small Share this post Link to post Share on other sites
Simsy 0 Posted November 5, 2008 Take the angled one right out and clean up with a wire brush as they get coked up ( watch the rubber seal), then replace and fully close. then adjust the small one at the back until it idles at 700 then open the angled on until at ticks over at 1000 job done You talking about adjusting the mixture screw on the AFM aswell? You don't really want to be messing with that without an analyser. Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted November 5, 2008 Sounds like he means the throttle stop to me, personally I always leave this well alone but each to their own. Share this post Link to post Share on other sites
davepug205 7 Posted November 5, 2008 No I meen on the throttle body. I had the same problem on my new 205 so I took it to my local dealer last Monday, he has worked there for about 20 years and told me to do exactly that, it now runs like a drem and idles perfect. hope this helps . Dave Share this post Link to post Share on other sites
adamc 0 Posted November 6, 2008 my car now runs sweet as a nut, cheers for the advice! Share this post Link to post Share on other sites
