swordfish210
Knocking From The Rear
swordfish210
Hi, last week i started getting a knock from the rear end of the car whilst turning corners. If i turn a left hand corner i get a "knock" from the rear then if i turn a right hand bend i also get a "knock" But if i turn left then left i only get a knock on the first bend and the same with turning right.
Anyone experinced this before, if so what was causing it and how do i sort it as i'm planning on doing a trackday on the 29th and i really want this sorted before then. Thanks. Mark
Sounds like something loose, get under there and give everything a good spanner check first off.
Ricardo
Check the rear 'sandwich' mounts. Mine did this and thumped.
Easy to check with a lever.
swordfish210
I would if i didnt allready have BBM Grp A mounts on there :D Thanks anyway though
Edited by swordfish210
Ricardo
swordfish210
  Ricardo said:
:D:( It's OK, how could you have known :(
de Noir
I had exactly this on my ex 306. Loud "klonk" sound every time you turn, right?
You should check rear ARB brackets inside splining for wear. Turning ARB a little may help.
Edited by MH_
