swordfish210 20 Posted November 4, 2008 Hi, last week i started getting a knock from the rear end of the car whilst turning corners. If i turn a left hand corner i get a "knock" from the rear then if i turn a right hand bend i also get a "knock" But if i turn left then left i only get a knock on the first bend and the same with turning right. Anyone experinced this before, if so what was causing it and how do i sort it as i'm planning on doing a trackday on the 29th and i really want this sorted before then. Thanks. Mark Share this post Link to post Share on other sites
Tom Fenton 1,561 Posted November 4, 2008 Sounds like something loose, get under there and give everything a good spanner check first off. Share this post Link to post Share on other sites
Ricardo 0 Posted November 4, 2008 Check the rear 'sandwich' mounts. Mine did this and thumped. Easy to check with a lever. Share this post Link to post Share on other sites
swordfish210 20 Posted November 4, 2008 (edited) I would if i didnt allready have BBM Grp A mounts on there Thanks anyway though Edited November 4, 2008 by swordfish210 Share this post Link to post Share on other sites
Ricardo 0 Posted November 4, 2008 I'll get mi coat! Share this post Link to post Share on other sites
swordfish210 20 Posted November 4, 2008 I'll get mi coat! It's OK, how could you have known Share this post Link to post Share on other sites
de Noir 0 Posted November 5, 2008 (edited) I had exactly this on my ex 306. Loud "klonk" sound every time you turn, right? You should check rear ARB brackets inside splining for wear. Turning ARB a little may help. Edited November 5, 2008 by MH_ Share this post Link to post Share on other sites
