NeilGTi85
Gti6 Sensor's
NeilGTi85
Hello All,
I've got a coolent leak from the stat housing which I now know is the gasket between the cyl head and the housing, I also need to replace the thermostat.
So I thought while I was doing that I might aswell replace the sensor's.
There's a Green (Coolent Temp Sensor?), Brown (Which I've also been told is a coolent temp sensor??) & a Blue one (Temp Senosr?).
Has anyone got any tips on how to do this? (Pic's would be good)
I know there's 3 bolts holding the housing on so that part should be ok :blush:
Cheers :lol:
Neil
NeilGTi85
Found this Pic which is very usefull, I take it all the sensor's just unscrew?
Neil
Edit - Just orderd the new thermostat with gasket and also the gasket for between the cyl head and the housing, all 3 sensor's for £56 from Peugeot themselve's!!
Edited by NeilGTi85
M@tt
you don't need the cooling fan one as the 205 has a seperate switch in the radiator for that.
NeilGTi85
I've recently brought a new rad from Nissans which I dont think have the switch??
I've also brought a twin fan setup of ebay for £26 (bargin!)
Neil
use the switch from your old Rad.
