gizzmo 3 1 Cars Posted November 1, 2008 hi bit of a novice but can some tell me if this is correct when bolting on a clutch cover plate / push type gearbox, should the fingers start to compress as you tightne the plate down Share this post Link to post Share on other sites
welshpug 1,666 Posted November 1, 2008 yes! fit the friction plate, then the pressure plate and tighten the bolts evenly by hand till the friction plate stays where its put and line it up, then tighten all the bolts up to torque with a dab of threadlock. Share this post Link to post Share on other sites
