205 & 306 Rear Discs Not The Same?
I have 306 trailing arms on my new beam, but having trouble fitting the discs, the calipers fit on fine, but have to be extended on their sliders all the way outwards for a 205 rear disc to fit... :D
I want to buy some new discs anyway, so what do i buy? I was pretty certain they're all the same, 205, 106, 306, ZX etc etc so come as a little surprise.
So does anyone know for sure that the 306's have a different rear disc offset or something? They're arms from a GTi6 with ABS sensors etc if that helps...
TIA!
Super Josh
GSF list a different P/N for 205 and 306 rear discs.
Josh
taylorspug
Yes from what ive seen the 306 discs have more offset to compensate for the ABS sensors, around 5mm. So if you are using the hubs with the ABS sensors get the 306 discs. :)
