mhyphenl 10 1 Cars Posted October 27, 2008 Hi there, Got a 1993 Gti with all the trimmings but the ABS unit seems to have been disconnected, the ECU and modulator are there all plugged in but no sign of any wheel speed sensors, anyone have any or know where they go! Any parts on the hubs any different from standard?? Share this post Link to post Share on other sites
Super Josh 4 Posted October 27, 2008 The hubs are different because the have the hole for the sensor and the driveshafts have the toothed ring. Josh Share this post Link to post Share on other sites
mhyphenl 10 1 Cars Posted October 27, 2008 The hubs are different because the have the hole for the sensor and the driveshafts have the toothed ring. Josh Righty then, so second question, can anyone point me to someone who may have hubs, driveshafts or sensors. I know alot of people get rid of the ABS but I want to put this baby back to original, I'm quite happy to swap some standard drive shafts on! Share this post Link to post Share on other sites
Miles 331 1 Cars Posted October 27, 2008 You'll have to have a good hunt around, The ABS system is very basic to say the least and not many people even Dealer's had much knowledge of it even when new, You could use 306 hub's but the camber angle is slightly different on them. Just make sure you have the leads at the back as it's all part of the loom that run's thru the car Share this post Link to post Share on other sites
