eob 7 Posted October 27, 2008 My car is a total hybrid, the Mi16 engine is wrapped in a 405 8v loom That means, none of the wiring guides work so I'm playing it by ear. One of things which definitely doesn't work is the rev counter I know the rev counter works off the coil, but what I need to know is which pins on the coil go to which pins on the dashboard, just in case anyone knows off the top of their head Thanks in advance Eamonn Share this post Link to post Share on other sites
GLPoomobile 958 Posted October 27, 2008 Should be Pin 1 on the coil plug, and should be a thick turquoise or green wire. It's a shielded wire. Actually, you'll find it will be a normal, thin wire where it terminates at the plug, but check back a few inches and it'll be much fatter where it becomes shielded. On mine it terminate at the 6 pin brown plug under the dash, at Pin 4 (there will be a green and yellow earth next to it at Pin 3, and Pin 5 will be empty). The configuration of these 6 pin plugs did change at various years of production, so yours might be different. Share this post Link to post Share on other sites
eob 7 Posted October 28, 2008 Indeed. I'm just wondering which pin(s) on the dashboard it actually runs to because I can obviously trace the pin from the dash down to the brown multiplugs? Share this post Link to post Share on other sites
