m_attt 31 1 Cars Posted October 25, 2008 driving back today after buying the turbo, temps seamed to sit at 3/4s ish, but if stood did seem to get very high. but the car pulls very well, no noises or smoke. is this down to poor cooling or could there be a blockage, if so is there a common place, what do your turbos run at temp wise? cheers matt Share this post Link to post Share on other sites
tom_m 0 Posted October 25, 2008 possibly a dodgy rad fan if its only getting hot stood still. check the connections, the earth and the temp sender in the rad. i've had a dodgy one cause me to boil over in a traffic jam before. Share this post Link to post Share on other sites
m_attt 31 1 Cars Posted October 25, 2008 when it gets hot or after stopped a fan is deffinatly on. do they both run at same time or is there one for normal running then the seconond when it gets to a certain temp? Share this post Link to post Share on other sites
rapidcossie 0 Posted October 25, 2008 possibly a dodgy rad fan if its only getting hot stood still. check the connections, the earth and the temp sender in the rad. i've had a dodgy one cause me to boil over in a traffic jam before. I have seen a good few turbos now and they all seem to run at 3/4, so iwould say nothing to worry about. If you are worried actually take a proper temp reading rather than working from a gauge that isnt calibrated for the turbo engine. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted October 25, 2008 Is the cooling system connected as it should be?, The last one I had which someone converted got it all wrong and it ran hot, Made it back to how a 205 should be and temps are per normal 8v Share this post Link to post Share on other sites
m_attt 31 1 Cars Posted October 25, 2008 normal running its up n down about the 3/4 mark, its just when its stopped or slow temps go nearlly to red. any links for pics how the plumbing should go its been a wile since i pulled a gti apart. cheers Share this post Link to post Share on other sites
m_attt 31 1 Cars Posted October 26, 2008 been out today, its deffinatly boiling over in traffic, when drivig temps are stable but when stopped it shots up. when really high can he fan really blowing, but cant tell when driving, are they expensive to replace? would it be better to have them bothon a manual switch in the car. cheers matt Share this post Link to post Share on other sites
Ant 2 Posted October 27, 2008 Matt, I had this issue when i first did the conversion. I solved it by cutting away all unnessasary plastic on the rad cowling and drilling 1" holes in the areas i couldnt cut away. I also moved the number plate to the bottom of the vallance, as this partially blocked the air intake. Thats all i did, but it increased air flow onto the rad. Now mine runs at 1/2 the temp guage, with no issues... well apart from pi**ing oil from the breather pipe, but thats a seperate issue lol Share this post Link to post Share on other sites
Ant 2 Posted October 27, 2008 Oh and i forgot to add, i do have twin fans, with a manual switch on the dash, but never need to use it. Might be worth having as a backup if it does boil over. For the cost of a switch and a few meters of wire, it might save your headgasket Share this post Link to post Share on other sites
welshpug 1,657 Posted October 27, 2008 is it really boiling over or just the needle getting high on the gauge? Share this post Link to post Share on other sites
m_attt 31 1 Cars Posted October 27, 2008 going by the picture above it runs about 90 on normal driving but stationory or slow traffic it goes up to 110, and the light will come on. and there is alot of pressure at the expansion tank. which is why i think its down to airflow or the fans. ill definatly wire a switch into it see how it goes, just hope it hasent toasted the head gasket allready. Share this post Link to post Share on other sites
dcc 855 Posted October 27, 2008 On my old 8v i had similar symptoms to this. 2-3 weeks later, my headgasket went. hopefully yours isnt as serious as mine was. Share this post Link to post Share on other sites
m_attt 31 1 Cars Posted October 27, 2008 ^^ this was my worry, locking the crankshaft looks fun if it is Share this post Link to post Share on other sites
craig f90 0 Posted October 27, 2008 My turbo also runs at about 90c in normal driving. I fitted a Revotec Fan controller and set it between 90c and 100c. its never had over heating issuses since. Its probably over cooling now. I am gonna fit a switch to the second fan soon. Just to be extra safe. Share this post Link to post Share on other sites
m_attt 31 1 Cars Posted October 30, 2008 for anyone who is interested, i wired the fans on separate switchs, then turno one on a 1/4 then one on at the 90 degree mark, seems to have solved the problem, was sat in traffic ages earlyer and temps kept nice an stable even dropped down towards 1/4 alot wen on the go. fingers crossed theres no lasting damage Share this post Link to post Share on other sites
