RINRIN
Low Rpm Missfire
RINRIN
Hi everyone,
We have miss firing effect on an engine between idle and 3k rpm, After 3k engine goes well, but below this rpm engine makes vibrations and stange miss firing.
We thought it is AFM but before changing it I need you advice
munster
Try the Ignition Amplifier.
1 FAT PUG
you tried plugs or condition of leads.?? one of mine looked ok, but on inspection when i took them off 1 fell to bits, new plugs and lead and all was good
Fox
I have this issue too, slight missfire now and again, usually when letting off the power.
I've changed the plugs and leads, will try a new amp
RINRIN
Thanks everybody, I will check ing. amp. then if not ,maybe we will buy an AFM
Guest dobbo
Avoid the cheap ebay ignition modules - I bought one of them and it caused a terrible misfire, I had to go back to a bosch one.
kyepan
these posts always start cropping up when it gets cold and damp... have a new set of plugs to go in tonight myself.
