vickiw106 1 Posted October 25, 2008 I have just put second hand bottom end on my 205 gti rally car due to the crank/rod bearing going on my old one I know the heads ok as I had it reconditioned when I took it of last But now it kicking out blue smoke when I rev the engine I know the bottom end has been stood around for a long time, could this be reason why it’s smoking Or have I got more serious problems I have not yet driven the car to see if it smokes under load Also both oil and water seem fine all bleed through ok and there is no excessive oil pressure problems Any help would be appreciated Thanks Ian Share this post Link to post Share on other sites
Tom Fenton 1,564 Posted October 25, 2008 If you are confident the head is Ok then it points to worn piston rings. As its for a rally car I'm suprised you are putting an unknown second hand bottom end in there, surely you want as much power as possible?? Share this post Link to post Share on other sites
vickiw106 1 Posted October 25, 2008 If you are confident the head is Ok then it points to worn piston rings. As its for a rally car I'm suprised you are putting an unknown second hand bottom end in there, surely you want as much power as possible?? when money is tight are the seller tells you that the complete engine was mint (and it did look mint) and second hand engine is as good as a new one. Share this post Link to post Share on other sites
Simsy 0 Posted October 25, 2008 If its smoking without load its going to be even worse under load i'd expect. Worn rings looks like the culprit here. You could try a compression test and see just how worn it is. Share this post Link to post Share on other sites
