16 Valving An Xu 8 Valve Block.
As the title says, is it possible to attach the front idler pulley to an Xu 8 valve block?
its the gti6 idler not the Mi16 tensioner I'm referring to, but they use the same fastener thread IIRC.
Sandy
Some of the late 8 valve blocks have the thread.
ok thanks sandy,
wondering if this block has it or not, I cant remember where the 16v tensioner attaches to the alloy block :rolleyes:
Sandy
I'll have a look later if I can remember!
Mandic
One goes to the hole below that one in which the plug/tap is in and second one goes to the hole above water pump.
Ziga
Edited by Mandic
thanks Ziga, that hole is present but not tapped, easy job :)
Mandic
You're welcome.
BTW, that third hole (between water pump and plug) is for locking that metal slider which holds belt cover.
Ziga
Thanks! I know the stud you mean :)
thought I'd add a few pictures, a brief glance indicates that there isn't anywhere to fit the idler pulley on the early block I have.
