Guest silverdales
205 Dashboard
Guest silverdales
Hello
Mine is a 205 cj convertable, I see in the scrapy a dash with the rev counter etc.... will this just plug in and work or is there connectors not in place for this?
Any help greatly appreciated!
Steve
Jrod
You will need to run the wiring from the fusebox.
Guest silverdales
Is this 1 loom from dash back to the fuse board and easy or is it loads of hassle ?
Jrod
Its easy but alot of hassle at the same time.
I had the whole dashboard out when I did it, not sure if you can get away with just taking the bottom half out but if all has to come out then its quite a lot of work.
Edited by Jrod
