Longfield 0 Posted October 20, 2008 Hi All, it's been a long time since I bought wheels for my 205. As such, I've forgotten the PCD, ET etc that I need. So what PCD and ET will I need for my car? My current wheels have 25mm spacer's attached to them if it helps. Thanks Longfield. Share this post Link to post Share on other sites
swordfish210 20 Posted October 20, 2008 the PCD is 4x108, centre hole is 63mm, and the offset is ET20. Thanks from memore so the information my be sketchy p.s. thats for a 1.9 GTI speedline Share this post Link to post Share on other sites
Arahan 4 Posted October 20, 2008 I thought they were 4x108, 65.1 centre bore and ET18. Share this post Link to post Share on other sites
Rippthrough 98 Posted October 20, 2008 I thought they were 4x108, 65.1 centre bore and ET18. As above Share this post Link to post Share on other sites
Longfield 0 Posted October 21, 2008 (edited) ok... by comparisson, I've seen a set of TH2 for sale which I believe have come off an Escort. They have a PCD of 108, ET 25 and Center Bore of 63... would these fit? Thanks Longfield. Edited October 21, 2008 by Longfield Share this post Link to post Share on other sites
welshpug 1,675 Posted October 21, 2008 depends how wide they are, if they're 6" wide, you'd need a 6mm spacer and the centre bore machined out to 65.1mm Share this post Link to post Share on other sites
Baz 421 Posted October 21, 2008 ok... by comparisson, I've seen a set of TH2 for sale which I believe have come off an Escort. They have a PCD of 108, ET 25 and Center Bore of 63... would these fit? Thanks Longfield. Centre bore would be 63.4mm, 1.7mm out from pug, so don't fit the centre spigot. As WP says it does depend on the width as to whether they clear the spring pan. Share this post Link to post Share on other sites
swordfish210 20 Posted October 21, 2008 I thought they were 4x108, 65.1 centre bore and ET18. Yeah, i said my reply should be taken with a pinch of salt............least i got the PCD right Share this post Link to post Share on other sites
