wardy18
I Need Wider Arches
wardy18
My current wide arches just wont be wide enought for the new 9" wheels im about to fit so can anyone recommend some extra wide arches either for a 205 or that i can adapt to the 205?!
i prefer the look of a simple arch rather than paying silly money for a T16 or Dimma kit
thanx
You've seen the 4/5" versions of the euro rallye style ones?
tom_m
the fronts will cover 9's for sure, but the rears are no wider than standard.
Batfink
9"!! do you run slicks? Interested to know how these grip and handle. I was going for 8" fronts and 7" rears for my track car.
cybernck
the fronts can be successfully used on the rear though :).
I think he was referring to the arches fitted on the actual car i posted. :)
cybernck
ofcourse, which is why i said the extra-wide fronts (from the picture)
can be used on the rear too, as they're not available as rears othewise :).
wardy18
yeh i was hoping that someone would post those arches up as i couldnt remember where they came from, have you got any more angles of them thou?! i see they mould into the front bumper but this would cause a problem because my bront bumper has been widened so at each side the bumper is actually wider than the wing with a little lip ontop to join with the wing, do these arches also just stop at the back of the arch or to they mould down lower down the wheel if you see what i mean?! i hate arches that are really wide and just stop half way down the wheel on the back side
These are the only images i have;
Edited by Baz
wardy18
how much are the front arches and where do you get them from?!
not so sure how the fronts would fit on the back also as the front wing has more of an angle to it that the rear quarter so may look funny on the rear
tom_m
its an ebay seller 'melnorthernline' but there don't appear to be any on the bay right now.
Batfink
James Lumeley had the same kit on his rally car and had 8" wide rears.
tom_m
he had to trim them somewhat to stop the rears eating the arches though iirc
wardy18
sorry just realised i didnt reply to this, yeh ive got 2 9" and 2 8", not sure which will go on rear and front yet, thinkin 9" on rear to stop the ass coming round but then i want them on the front to pull me round the corners and stop understeer, ill work the arches so that i can swap them around front to back and test!!
i think im just gonna work with the arches i have at the moment and cut them and extend them, fibreglass ity here we come, will post some progress pics
lybker
Hi
I have exact same problem - am fitting 17x9", but choose to go for this kit:
http://cgi.ebay.de/Peugeot-205-verbreiteru...id=p3286.c0.m14
Not to much progress yet - only fitted one arch, and it will still be a close fit:
http://www.bilgalleri.dk/html/gal_visbil.a...&ipc=352821 (last 4 pics)
btw tires i will be using is Dunlop 235/610
wardy18
still looks very tight for room thou even with those arches, ill just cut mine and set it in place with some ally strips then fibrglass the gap then remove the ally, shouldnt be too bad just wanted to see what else was out there
S13Nick
the arch's off that white 205 are in my car!!! if someone wants to buy then, send me an offer
