jas-E 1 Posted October 19, 2008 Hey, Im on the final stages of my mi16 conversion and have a question of the water-oil heat exchanger plumbing. I have decided to keep my 1.9 8v water-oil heat exchanger (the remote one which sits infront of the gearbox). Can anyone please guide me on which pipes they used from the thermostat housing to the top of the radiator? The mi16 pipes i have all go to where the oil filter would sit, so are no good - and if i try and locate them to the exchanger i end up kinking the pipes. Same with the 8v pipes, but this time the kink comes on the big hose going to the thermostat housing on the head. What setups have people used doing this kind of conversion? Thanks for all help and advice. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted October 19, 2008 To use the remote oil water heat exchanger located in front of the gearbox you just need to use the correct top hose with the two pipes that branch off it down to the exchanger as fitted to your 8v. Should fit straight in with no need to change anything except remove the Mi heat exchanger from the block to fit the remote adaptor plate there. Graham. Share this post Link to post Share on other sites
