jengis 0 Posted October 17, 2008 Hi, I have been offered an XSi 8v engine with ex manifold, inlet, loom and ecu - everything really. But it looks like the inlet wont fit, much like with 16v conversions. Those who have used this engine, how did you run it? Is there an easy option, for example using my inlet and management (don't want to modify the port shape though), or cutting down the XSi manifold? Secondly, what are the ratio's for the XSi gearbox, I can have this too if I want. Lastly, are these ECU's likely to be locked? Share this post Link to post Share on other sites
welshpug 1,677 Posted October 17, 2008 I wouldnt bother with this engine myself, too heavy and underpowered to be an upgrade over the 1.6, though they do run better management. Share this post Link to post Share on other sites
Anthony 1,003 Posted October 17, 2008 Works well enough using a 1.6/1.9 inlet manifold (reshape the ports to match) with a dizzy and Jetronic management, and a GTi or hotter cam. Something like 130-135hp and similar torque. For the amount of work though, you might as well just stick with a 1.9 8v. Original XSi ECU will likely be locked unless it was from a very early car, or the seller knew to unlock it before removing (unlikely) Share this post Link to post Share on other sites
jengis 0 Posted October 17, 2008 Works well enough using a 1.6/1.9 inlet manifold (reshape the ports to match) with a dizzy and Jetronic management, and a GTi or hotter cam. Something like 130-135hp and similar torque. For the amount of work though, you might as well just stick with a 1.9 8v. Original XSi ECU will likely be locked unless it was from a very early car, or the seller knew to unlock it before removing (unlikely) Hmm, thats what I thought. A search threw up the option of 405 SRi (?) or BX GTi inlet manifold. I have never seen these but are they pretty much the same as 205 Jetronic inlet but with round runners? Oh, and 1.9 8v is always an option but I have a nice running 1.6 GTi and a 2.0 engine with all ancillaries sitting on a mates garage floor.... seems rude not to! Share this post Link to post Share on other sites
jengis 0 Posted October 18, 2008 I think it will be worth it. I will use the Jetronic management and my inlet to keep things simple. I plan to do a DIY job on the port matching, any pics or help with this would be apreciated. Cheers Share this post Link to post Share on other sites
ifcho 0 Posted October 24, 2008 or use it as a base engine for turbo conversion Share this post Link to post Share on other sites
Baz 421 Posted October 24, 2008 Hmm, thats what I thought. A search threw up the option of 405 SRi (?) or BX GTi inlet manifold. I have never seen these but are they pretty much the same as 205 Jetronic inlet but with round runners? Oh, and 1.9 8v is always an option but I have a nice running 1.6 GTi and a 2.0 engine with all ancillaries sitting on a mates garage floor.... seems rude not to! The xu10 is pretty different in design to the gti one. Why change the 1.6 if you have a good one! Share this post Link to post Share on other sites
jengis 0 Posted October 25, 2008 The xu10 is pretty different in design to the gti one. Why change the 1.6 if you have a good one! By "nice running" I meant I have spent money getting the chassis sorted, love how sharp it is. The engine is a bit smokey and just a wee bit gutless. I like the revvy nature of the 1.6 but I have always thought the magic of hot hatches is that there is a big, torquey engine in a light, agile car. Can anyone confirm that the iron block is "only" 23kg heavier than the alloy one? I will re-locate the batery to the boot to restore the balance in that case. Like the option of turbo in future!! Share this post Link to post Share on other sites
craig f90 0 Posted October 25, 2008 or use it as a base engine for turbo conversion Too right. Be pointless swaping a 1.6 for the 2.0 N/A unless its gonna be powered by a 16v or a turbo. By the time youve put the time and money into your conversion you'll probably be hoping for loads more oomph for your efforts. Share this post Link to post Share on other sites
jengis 0 Posted October 25, 2008 Too right. Be pointless swaping a 1.6 for the 2.0 N/A unless its gonna be powered by a 16v or a turbo. By the time youve put the time and money into your conversion you'll probably be hoping for loads more oomph for your efforts. Thanks for your thoughts on this, all good advice. Surely it depends how much time and money though. I can't afford Mi, S16, GTi-6 conversions etc. I need to get my engine out to stop the rot in the engine bay and fit a new clutch at some point soon. I have been offered an XSi engine for "mates rates" and its seems a good idea to me. Even if it only makes 120 bhp, the added torque will be worthwhile. Anyone on here actually done the conversion? How will the jetronic setup cope with the engine? I imagine a bit of tweeking with the afm and the dizzy will get it near enough? Share this post Link to post Share on other sites
ifcho 0 Posted October 25, 2008 getting rid of the jetronic is one of the main reasons for fitting this engine.. Share this post Link to post Share on other sites
jengis 0 Posted October 25, 2008 getting rid of the jetronic is one of the main reasons for fitting this engine.. Do you have any tips for making the inlet maifold fit if I swap to magnetti Marrelli? Share this post Link to post Share on other sites
Anthony 1,003 Posted October 25, 2008 Too right. Be pointless swaping a 1.6 for the 2.0 N/A unless its gonna be powered by a 16v or a turbo. By the time youve put the time and money into your conversion you'll probably be hoping for loads more oomph for your efforts. Can't say I agree with that at all. A 1.6 - 2.0 conversion is almost as straight forwards as a 1.6 - 1.9 8v conversion, and similar money too (given that the engines are cheap). For that you're going to get 20-25hp more, and probably another 30-35lbft torque, and keep the punchy power delivery of an 8v. 16v conversion you're talking alot more time and effort, and frankly I'd rather have the 1.6 GTi engine than a standard 2.0 8v Turbo even without taking into account the significant costs and effort of doing the conversion properly. Share this post Link to post Share on other sites
projectpug 0 Posted October 26, 2008 Why dont you like the 2.0 turbo Anthony? Share this post Link to post Share on other sites
