boldy205 75 Posted October 14, 2008 Hi, i have searched, and posted before but never really got an answer. My question is, what are the two senders on the front of a GTI6 block, one behind the starter with a short wire that seems bo be perminatly fixed to it, and a sender to the left of it. I presume thay are both oil senders? If so what do they do? Many thanks Matt Share this post Link to post Share on other sites
welshpug 1,675 Posted October 14, 2008 the one with a length of wire attached is the oil level, the other will be oil pressure switch, quite rare for a gti6 to have a gauge sender fitted. Share this post Link to post Share on other sites
boldy205 75 Posted October 14, 2008 Ah so for fitment to a 205 i wont need the one on the right (oil level) The one on the left then, the oil pressure switch, will just be the light? Or the guage as well? Thanks Matt Share this post Link to post Share on other sites
welshpug 1,675 Posted October 14, 2008 it'll be just the switch, so you will either need to fit a sender from an S16/Mi16/2.0 8valver, or get an adapter from Miles to use the original 205 8 valve item. Share this post Link to post Share on other sites
boldy205 75 Posted October 14, 2008 Thank you very much Welshpug! Sorry for being cheeky! Share this post Link to post Share on other sites
boldy205 75 Posted October 14, 2008 So the S16 etc senders will fit where the GTi6 pressure switch was? and will it do both the light and the guage? Thanks Share this post Link to post Share on other sites
