djinuk
Lots Of Vibration Through The Steering Wheel
djinuk
I have huge amounts of vibration through the steering wheel at aroudn 75/80 mph. The car has always been like it since ive owned it, but now i have a 330mm steering wheel its unbearable..
what could be the culprit. ?
NeilGTi85
When was the last time you had your wheel's balanced and tracked?
Neil
JSF2004
Neil
Agreed... a few quid spent at your local tyre centre should solve or at least point you in the right direction....
balancing, NOT tracking.
Yup, out of balance wheels would be where I'd start. You can try swapping the fronts and rears over to see if that improves matters.
As a general rule, any vibration that starts over around 60-70mph in a straight line is normally wheel balance. If it largely comes through the steering wheel, then it's probably the front wheels, whereas if you don't get much feedback through the steering wheel then it's probably the rears.
jeremy
I had a similar fault, it turned out to be a worn TRE.
djinuk
recently had 2 new tyres.. and matter didnt change,. ill ask them to balance the wheels..
BERTMAN
id definently get the wheels balanced first
Edited by BERTMAN
