Guest Cap Posted October 11, 2008 Slight problem with car as in it wont start, found a block connector and 3 wires, not sure which order they should be connected, any help will be appreciated. Share this post Link to post Share on other sites
Arahan 4 Posted October 11, 2008 If the connector is yellow then that should be connected to the dizzy i think Share this post Link to post Share on other sites
Guest Cap Posted October 11, 2008 The plug is off the dizzy, the 3 wires with connectors are from somewhere in the loom, can not find another plug for it to go into so i believe the origonal plug has been cut off the loom at some point for one reason or another hence my predicament with connecting it up lol Share this post Link to post Share on other sites
DamirGTI 344 Posted October 12, 2008 (edited) Yes , there should be black 3pin female connector in which you plug this yellow one ... you should be able to find such connector on your local scrappy or ask around here im sure that someone has it - it's the part off the ignition amp and coil wiring/loom .. Anyway , looking on the yellow 3pin connector as it is on the picture it goes like this : .. but id fit proper connector cos this can unplug itself during the driving easily which will be instant engine stopper .. Rgs ! Damir Edited October 12, 2008 by DamirGTI Share this post Link to post Share on other sites
Guest Cap Posted October 12, 2008 Thank you worked a treat and car fired up first time , however now leaking water from water pump housing, looks like ill have to bite the bullet and rebuild and engine now thank you Share this post Link to post Share on other sites
