pete1986 2 Posted October 10, 2008 Only the top element of the demister works on my 309. It wasnt working at all when i first bought the car but i checkedd the connectors, wiring and then foundd the relay was knackered. After replacing that, im left with the above problem. Its a pain in tthe arse now the cold mornings are here! Do the elements run in a series? ie. if there was a break before the second element would none work below. If not, what else could i try to fix it? Thanks for your help Share this post Link to post Share on other sites
pete1986 2 Posted October 12, 2008 Does no one have any input??? Im sure alot of 205/309s have this problem. For example, in my 205 only every other element works Share this post Link to post Share on other sites
nick9one1 2 Posted October 12, 2008 If you can determine if any elements are broken you can buy a small glass vial of what looks like silver paint from hellfrauds to join them back up again. I used it once on my puma and it worked really well. Share this post Link to post Share on other sites
pete1986 2 Posted October 13, 2008 (edited) Excellent, cheers Nick. I was hoping it would be a cheap and easy answer. Element are definately damaged on my 205 but havn't check them on the 309. Edited October 13, 2008 by pete1986 Share this post Link to post Share on other sites
Ricardo 0 Posted October 19, 2008 pete1986 said: Excellent, cheers Nick. I was hoping it would be a cheap and easy answer. Element are definately damaged on my 205 but havn't check them on the 309. Yeah I got some for mine but it was the spde contact pad only just hangin on. It broke off when the tailgate was slammed so I got some adhesive from ebay (USA) now all elements work excellently! I also got some conductive paint from Halfrauds! just lightly wet n dry the element lines each side of the brake and clean with brake cleaner or isopropanol or better still surgical spirit! then paint a line across the gap(s)! I used to work at a pcb manufacturer and we used to repair circuit boards like this! Share this post Link to post Share on other sites
