platty
Clutching At Straws
platty
Been out trying to connect up the clutch cable to the Xsara box. My question are:-
Is the clutch fitted to the VTS box the push type?
Do I need to replace the clutch with a pull type?
The bracket on the front of the gearbox for the clutch cable will fowl the engine mount if used.
Xsara VTS uses exactly the same clutch as the GTi6 (and the TD engines) which is a PULL type.
you can swap the arm and fork for a PUSH type and use a 1.9 Mi16 clutch+release bearing, and a BE3 205 cable.
platty
Bugger.
Gearbox off again then.
Cheers Welshpug.
so the fixed bracket on the box gets in the way of the bracket/battery tray that bolts to the chassis leg?
platty
Yes, it fixes to the box in three places. The leg that would normally bolt to the box under the battery tray on the Xsara would now fowl the Bracket by about 15 mm more so with engine movement.
I nearly took the grinder to the Bracket B)
Edited by platty
why not? B)
people bash their bulkheads to make these engines fit...
jonnie205
leave the clutch arm and clucth as it is, use the std be3 cable with a 10mm spacer and its fine. The clutch cable braket will also miss the battery tray i just done this exact setup on a 205
whizzer71
Yep it all fits and works very well !,You just need to use the relevant type of clutch !
platty
why not? ;)
Don't tempt me.......I don't take much persuading
You mean lower the engine? RS2000 mount and space the gearbox mount 10mm?
If so, that will help with slam panel clearance too.
taylorspug
No he means a spacer on the cable i think, as its too long with the pull type clutch lever setup. Ive got a GTI6 clutch setup on mine and its lovely, pedals alot lighter and feels nicer than a push type. I had to grind the bracket away a touch, but its only 5 mins work. Im doing another conversion for a customer with the same setup soon.
