Moz_Goodwood 0 Posted October 7, 2008 (edited) how hard is it to drop a fuel tank (not take off completely) on a 1992 309 gti??? i need a farting bit of welding doing on the inner rear passenger side sill but the welder i use says its to close to the tank and wants it dropped Edited October 7, 2008 by Moz_Goodwood_309 Share this post Link to post Share on other sites
welshpug 1,666 Posted October 7, 2008 (edited) Remove exhaust, disconnect fuel pump and fuel filler+breather (make sure its near empty, 1 so you dont spill any and 2 so its lighter!) then 2 nuts. If you're welding or grinding you should remove it completely. Edited October 7, 2008 by welshpug Share this post Link to post Share on other sites
Moz_Goodwood 0 Posted October 7, 2008 how would i disconnect the fuel filler? Share this post Link to post Share on other sites
welshpug 1,666 Posted October 7, 2008 undo the jubilee clips!!! its all pretty easy when you get under there. Share this post Link to post Share on other sites
Moz_Goodwood 0 Posted October 7, 2008 (edited) i knew that i was just testing you Edited October 7, 2008 by Moz_Goodwood_309 Share this post Link to post Share on other sites
