Doof 11 Posted October 2, 2008 Anyone know how you get the diff bearings off? I'm hoping they're not just pressed on as i dont have a press to put them onto my new slippy diff. Alternatively, anyone know where you can get new diff bearings? Thanks, lewis Share this post Link to post Share on other sites
Toddy 7 Posted October 2, 2008 Anyone know how you get the diff bearings off? I'm hoping they're not just pressed on as i dont have a press to put them onto my new slippy diff. Alternatively, anyone know where you can get new diff bearings? Thanks, lewis Miles for the bearings and local engineering shop to press old ones off and new ones off cost me £10 Share this post Link to post Share on other sites
Miles 331 1 Cars Posted October 2, 2008 As said, I supply the bearing's, Fitting them is easy as you can use a socket and a vice Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted October 2, 2008 Be warned you may have to get the dremel out on the diff housing as mine and ive read others have had the new lsd foul on the housing! all worth it thou, jus be careful on that first foot full of throttle Share this post Link to post Share on other sites
Alan_M 66 1 Cars Posted October 3, 2008 The Quaife diffs are OK I think, its the Trans-X diff that you need to grind away some of the diff casing to fit. Doesn't take long though with a Dremel, if needs be I can scan in the doc's I got with mine (new) that show exactly where you need to grind away, and tells you how check the setting you have Share this post Link to post Share on other sites
Alastairh 47 Posted October 3, 2008 Kaaz also require a grind away also. Share this post Link to post Share on other sites
jonnie205 1 Posted October 3, 2008 to get bearing off you will need to use a knife edge tool in a press, and a socket and press will get them on Share this post Link to post Share on other sites
Doof 11 Posted October 4, 2008 Thanks for the info guys, the diff is a Kaaz jobbie so i'll post back with results when i've tried it all Share this post Link to post Share on other sites
