Guest martin01743
Which Steering Rack
Guest martin01743
I have just converted front end from 14XS to 16GTI subframe 309 wishbones, shafts and hubs, My question is can I use the 14XS steering rack. If not what should I use?
Jrod
XS rack will be fine.
It'll be just fine like Jordan says but you will need to wind the track rod ends out approx 10mm each side & then have it tracked up professionally otherwise you'll have both wheels toeing out when you try to drive it. :ph34r:
Graham.
Guest martin01743
Thanks Guy's you just saved me money and work :angry:
