Kriss
Exhaust Manifold
Kriss
Having a bit of trouble removing me exhaust manaifold, all the nust are fubad, spanners are just slipping on them. Thenut splitters i have cant get onto them so now im stuck with a car with a broken exhaust i cant get on the road ;)
j_turnell
Either cut them off with a dremel or alike, or get some snap-on bolt extractors, never fail.
lagonda
Try hitting them with a hammer & flat punch. The problem is rust, & with a bit of luck the impact shock will break up enough of it to loosen them. Use mole grips or see if you can knock on a smaller size socket.
Kriss
the problem i thought with the dremel is would i be able to acsess the lower one's.
Never thought of a centre punch, snapped my last one ;) trip tohalfraudsfor me then. Any other idea's??
j_turnell
The lower ones would probably be easier i would have thought, just do it from underneath.
steve@cornwall
I assume these are the earlier 10mm ones? Use an old 3/8 socket and persuade it to fit on the nuts with a hammer! works brill!. Try and just "crack" the seal on each nut, rather than removing one at a time as this will keep the last couple from having too much pressure put on it by the manifold which may well be heat warped
Peetypug
you can get some irwin nut/bolt extractors
THESE
they work a treat
