MerlinGTI 3 Posted September 27, 2008 sorry for the pants pic, it was incredibly hard to capture. What im worried about is the small gap all around the disc inside. Saying this all 3 throttle bodys I have are the same, but then again they are all like 15 years old! Should there be a gap or an air tight seal? Cheers Share this post Link to post Share on other sites
Cameron 16 Posted September 27, 2008 (edited) I can't see it causing a problem, unless you're finding you have an unusually high idle speed. If you do want to sort it then (carefully) undo those screws in the centre and then open and close the throttle you should be able to get the disc to sit back in the centre properly. Remember you might need to adjust the throttle position switch and idle screw after too. Edited September 27, 2008 by Cameron Share this post Link to post Share on other sites
jord294 94 Posted September 27, 2008 (edited) they're all the same they should have slight gap Edited September 27, 2008 by jord294 Share this post Link to post Share on other sites
matty_gti 20 Posted September 27, 2008 they're all the same they should have slight gap Every TB ive had has had that slight gap so theres nothing to worry about. Share this post Link to post Share on other sites
MerlinGTI 3 Posted September 28, 2008 exellent one less thing to re-furb/fix/throw away! Cheers gents Share this post Link to post Share on other sites
GLPoomobile 958 Posted September 28, 2008 If there was no gap, how would it idle? It'd have no airflow! Share this post Link to post Share on other sites
welshpug 1,666 Posted September 28, 2008 throttle bypass screw Share this post Link to post Share on other sites
