sss_205GTI
Replacing Top Mount Bearings + Rubbers
sss_205GTI
The top mounts n bearings n rubbers - I have group N top mounts - still got a knock - am looking at replacing the bearings n rubbers - will standered / after market bearings n rubbers fit?
Getting myself abit confused - thought the actual top mount was seperate from the bearing and rubber?!
Yet euro car parts just quoted me for the top mounts (which he said are the rubbers?) and the bearings... I always thought the top mounts were the metal plate?!
Help?
cybernck
here you can see an exploded top mount (luckily not literally :P):
don't get those aftermarket OE-replacement rubbers, they are too soft.
get just the bearings from SKF dealer and FastRoad or Grp.N rubbers from BBM.
the metal part you can refurbish if it's rusty, but that's it.
hope this helps.
sss_205GTI
Thankyou very much :P
number2301
Metal part can be bought from Peugeot, something like £40 a side but it comes with the rubbers.
Just to reiterate, GSF also sell 'top mounts' which are just the rubbers.
GLPoomobile
The Pug top mount kit includes everything IIRC - metal plate, rubber donut, bearing, strut nut and mounting nuts. Last time I checked it was circa £50 per side if you include VAT.
If getting aftermarket bushes (the rubber donut) from somewhere like BBM, I'd go for the fast road version, which should be somewhere between OE standard and Group N for stiffness. I had BBM Group N ones on my old 205 with standard shocks and Eibach 7001 springs and found the ride incredibly crashy. I'd had the same suspension setup with standard bushes for a while, and the swap to the Group N ones was quite significant in my view. Fine for track use, but I didn't like them at all for the road. I'd maybe try the fast road ones one day, but more likely to just get OE ones from Pug.
sss_205GTI
SKF - when i go onto a website e.g. bearing boys
i kinda have the following reaction :lol::lol::P
McDude
I think it has all been covered in the above.
I'm running GrpN top mount rubbers and don't find them harsh at all - steering is very direct as a result with no play or slop.
Metal plate and bearing are OE items.
pete1986
Just to confirm, everything on the left hand side of cybernck's photo is include in peugeot's top mount kit. The kit cost £37 a side when i bought some a few months back
Jrod
Also use Group N rubber and really like them, My car is just for a toy now though so I wouldn't care if it was crashy if it handled well. :lol:
GLPoomobile
No doubt Sir Skip Of Brown might have something to do with that :lol:
Old OE shocks with -40mm Eibach springs isn't exactly the final word in damping finesse (although I preferred the control to my current Koni kit). Having the Group N top mount bushes was probably just a step too far. The Skip Brown setup is carefully matched, and so the damping is probably better able to cope with those bushes.
sss_205GTI
Right well ive gone for some Group N rubbers and GSF bearings. Im not really bothered about the finer issues of ride or handling (for now!) more i want to see if this cures the horrendous knock im exeperienceing.
Thanks for making stuff clear guys - appriciate it :D
Simsy
Sorry to resurrect an old thread here, can you get the bearings from GSF? The 306 had a top mount and bearing (available from GSF) and they were spot on, the metal plate doesn't really require renewing unless its rotted to pieces which i doubt so i just want the bearing and rubber parts.
Peugeot dealers are extremely hilarious in their pricing of these sort of parts too, so i'll try and avoid them if i can!
You can yes, for about £8 iirc, can't find the part no. i'm afraid though!
CosKev
Try your local motor factors,I got mine from Motaquip,£11 per side and they were SKF bearings,that included standard rubbers too :lol:
Simes
I've just gone back to standard rubbers after 4 or 5 years of group N. I haven't noticed any difference apart from it is less crashy and noisy.
Perhaps I'm getting old.
Super Josh
I think it is this one
N45710STRUT TOP BEARING BERLINGO STRUT TOP BEARING 8.75
Can anyone confirm?
Josh
yes that's the one, pretty much every single PSA vehicle uses that bearing.
MrG
does anyone have the peugeot part number for the top mount set?
Number 2 on the left, 5031 25 £49.93 inc vat each side
MrG
thank you WP
Can anyone confirm?
Josh
Is that a Pug part number then??
Super Josh
No GSF Mate
Josh
Simsy
I'd go GSF for the lot then. I did with the 306 and had no issues. Unless anyone would advise going to pug? I'm only planning on doing them once! :)
GSF dont do the complete lot, only the bearing + donut.
cybernck
like i've already said:
  Quote
