johnnyp 1 Posted September 24, 2008 hi i was looking at service box and iam trying to get a water block union that goes on the back off the block but i was not sure which part number i needed sorry for being so thick. Does any one know what the part number is for a 1.9 mi16 thanks Johnny Share this post Link to post Share on other sites
DamirGTI 344 Posted September 24, 2008 (edited) http://www.stuartmcguire.co.uk/pug/GB/405F/1/13E10A.HTM This one : 1336 60 ? should be same as 1.9 8v part anyway Damir ..almost forgotten , dunno if you can still chose in between the two , they've been made form aluminum (for early engines) and plastic (for later) .. i prefer aluminum ! Edited September 24, 2008 by DamirGTI Share this post Link to post Share on other sites
johnnyp 1 Posted September 24, 2008 hi thanks i thought the mi16 had 3 outlets on it Johnny Share this post Link to post Share on other sites
DamirGTI 344 Posted September 24, 2008 Well i'm not sure about that , didn't have Mi engine yet .. but from the catalogue it looks like the 2 outlet type is for early Mi-s and the other one , 3 outlet type for later Mi engines someone will verify this .. Damir Share this post Link to post Share on other sites
taylorspug 7 Posted September 24, 2008 Yes the MI ones are different to the 8v items. I usually use the 8v ones as you can then run the std 8v hose setup. Use the MI one if you still have the metal water pipe running across the back of the head. Share this post Link to post Share on other sites
James_R 3 Posted September 24, 2008 Beaten, but was going to say, if you round file the water pipe across the back of the exhaust mani then 8v, also less to break or bleed when its in. Share this post Link to post Share on other sites
