paulfreeth 0 Posted September 22, 2008 Hi all, i recently brought some challange bilstiens for my 205 and when fitting them i couldnt use the origanal bump stop, as the inserts are much bigger on the new struts. I looked at cutting the hole out so they would fit but there wouldnt have been anything left! I ve fitted them without any for now and was just wondering what others had done, or weather i need worrying about them. I use the car for roadrallys so think that it might be wise to have some. The ride height is standard on 165lb gravel springs. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted September 22, 2008 Dont worry as the bump stop's are in the damper as these are upside down, you may think they have a huge damper rod but when you see the rod it's about 15mm in Dia Share this post Link to post Share on other sites
Batfink 201 Posted September 23, 2008 all yellow bilstein dampers and inserts have internal bumpstops Share this post Link to post Share on other sites
paulfreeth 0 Posted September 23, 2008 Thats ok then, thanks for your replys. Im well impressed with the set up its totaly changed the car! Share this post Link to post Share on other sites
