gtiles85
Another Gti6 Gearbox/clutch Question
gtiles85
Getting ready to put the box on the engine but i'm now stuck, im a little bit confused about the release bearing, from what it looks like on mine its constantly pushing on the clutch and when you put the clutch pedal down it takes off the pressure.
This is what it looks like before you put the clutch in
http://i81.photobucket.com/albums/j216/st2.../DSCI0006-9.jpg
And this is what it looks like when the clutch is pressed in
http://i81.photobucket.com/albums/j216/st2.../DSCI0010-4.jpg
But when you release the clutch the bearing doesn't seem to return, im thinking that i am missing something like a spring.
I'm wondering if anyone has got any ideas or has an exploded diagram of the clutch unit ?
Thanks in advance, Les. :)
I swapped the entire mechanism off a 205 BE3 gearbox.
gtiles85
So you still have the 6speed box then ?
I'm confused because i have never seen a clutch like this, and it may be correct but i dont want to have to put it all in and find out that it doesn't work .
jonnie205
that bearing you can see there is the remains of a gtig relaese bearing that has been broken from clucth whilst somebody has butchered teh gearbox off. If you are using a gti6 box then either swap to a std 205 type be3 setup and mi16 clucth or use gti6 clucth and clucth arm setup and a modded 205 cable
gtiles85
Ok that makes alot of sence now ( will be having words with the guy who sold it to me) I will probably use the gti6 setup but i take it i need a new clutch now ?
Cheers, Les. :unsure:
jonnie205
yeah you will need a new clutch, i got loads a realy good used ones if you want one
