gtiles85
Gti6 Engine Conversion.
gtiles85
Hi, I am in the process of doing a gti6 engine conversion to my 205 but i have got a quiery. My 205 doesn't have power steering and the gti6 does, so did the 309 i got it out of. The problem i have got now is with the drive belt. Me being me, i just assumed that the gti6 drive belt was tentioned by the alternator, but its not.
The question i want to know is how do i get round it, i was thinking about just leaving the power steering pump there so its working as a runner pulley, but if i did that would it seize up ?
Thanks in advance !
Les. :angry:
NeilGTi85
A quick search through the projects and you'll find what your looking for
Neil :angry:
Edited by NeilGTi85
gtiles85
Neil :angry:
Thanks for the link but i cant seem to find what i am looking for ?
NeilGTi85
Sorry the link I did post was for someone who retained the PAS.....ive seen some info about how to run a dummy Pump though somewhere....
Neil
Peetypug
you can remove the PS pump
then get a 8v alternator tensioner and alter it so you only run the the alternator on a shorter belt
try this for a start
will have a look for more in a min
hodgy
ive just got a smaller belt and by passed the pump with mine. i still have the air con pump tho
gtiles85
Ok, thanks for the help guys, i will hopefully have the original engine out of the 205 tomorrow so i will have a ganders when both the engines are next to each other .
Cheers, Les. :angry:
GTI6BOY
i have the 306 rallye set up which does not use air con and a smaller belt to by pass the p/s pump
boldy205
If you look at where the crank pully and the Alt pully are, about half way between the two is a M8 hole, to which i have fitted an old GTI6 manual cambelt tensioner pully to. I havent yet chewcked if it will work but looks VERY good!! Thanks to a certain chap on this forum for that one, cant remember who though sorry!!
