Andy F
Ignition Barrel
Andy F
hi
im currently stripping my 205 and am struggling to get the ignition barrel out of the column. Ive taken the bolt out and tried pushing the pins in from underneith.
am i missing something?
thanks
Super Josh
You need to put the key in the lock, then turn it to the first position, then the pin will push in. Should just slide out then :blink:
Josh
Ryan
Sometimes it's first position, sometimes it's half way between first and second. There should be a mark on the barrel - line the key up with the mark and then you should be able to push the pin in.
Andy F
ah excellent
thanks for your help
:rolleyes:
