projectpug 0 Posted September 12, 2008 Hi all, Will a magnex manifold fit an omp exhaust? Also when fitting the 4-1 magnex do you feed it in from top of engine or from underneath? Thanks Phil Share this post Link to post Share on other sites
CosKev 16 Posted September 13, 2008 Hi all, Will a magnex manifold fit an omp exhaust? Also when fitting the 4-1 magnex do you feed it in from top of engine or from underneath? Thanks Phil Not sure on OMP question.Find out the sizes of the two and should be able to get some pipe from Tweeks to match them together You do feed it in from top of engine,I had to remove bolt from rear eng mount and pull engine forward to get enough room to clear head and manifold studs. Share this post Link to post Share on other sites
hodgy 0 Posted September 15, 2008 it doesnt fit.the omp need widening as its the exact same diameter as the magnex Share this post Link to post Share on other sites
