Subby 0 Posted September 10, 2008 (edited) Just started changing my oil on the mi16, and i see this in the oil filler: It was worse but i wiped it off, and realised i should probaly check and make sure something isnt fubared The engine runs fine, so shall i just continue with the oil change or ? Any help would be appreciated thanks. Edited September 10, 2008 by Subby Share this post Link to post Share on other sites
24seven 104 Posted September 10, 2008 it's normal to find mayo in there. if there's mayo in the water, that's a diffeernt story. Share this post Link to post Share on other sites
Subby 0 Posted September 10, 2008 ok thats awesome. Water seems fine, so thanks Share this post Link to post Share on other sites
NeilGTi85 5 Posted September 10, 2008 I thought the same thing when I brought my first MI, give it a good run and it'll clear. Neil Share this post Link to post Share on other sites
nick 3 Posted September 10, 2008 The reason pugs in general do this is because the filler is remotely mounted and it's plastic, it doesn't get any heat to burn this crap off like a conventionally mounted (on top of the camcover) oil filler. Nothing to worry about. Nick Share this post Link to post Share on other sites
Stu 18 Posted September 10, 2008 As above, mine gets really creamy after a few short drives, so long as theres nowt in the coolant and you arent using any it'll be fine. After a few sessions at Combe over the weekend mine was clean as a whistle! Share this post Link to post Share on other sites
Ethos 0 Posted September 10, 2008 I find I get this pretty bad too, infact sometimes if I take the pipe off from the throttle body to the oil filler off I actually get beads of water? Mayo seems to build up fairly quickly, such an annoying design! Share this post Link to post Share on other sites
Stu 18 Posted September 11, 2008 Yeah i do on occassion too, depends on how the car has been used really. Mine is a little worse as ive got no gauze filter in my cap, so i daresay it'd be a little better if i had that in! Share this post Link to post Share on other sites
Miles 331 1 Cars Posted September 11, 2008 I'd change the tower or you'll get all the metal filter parts drop into the sump to get spun around the bearing's Share this post Link to post Share on other sites
tri_longer 25 Posted September 11, 2008 Has anyone had a filler welded onto their cam cover? I have seen one for sale once on fleabay and was considering this as an option. Share this post Link to post Share on other sites
welshpug 1,666 Posted September 11, 2008 (edited) some later XU10's and the DW9 have rocker cover mounted fillers Edited September 11, 2008 by welshpug Share this post Link to post Share on other sites
Stu 18 Posted September 11, 2008 I'd change the tower or you'll get all the metal filter parts drop into the sump to get spun around the bearing's Was that for me Miles? It isnt that the filter has broken up and ended up down the tower, when i rebuilt the engine i cleaned all the breathers out and the gauze filter looked a little worse for wear, so as an intermediate step i removed it as i didnt want any particles finding their way into the fresh engine. I just never got round to replacing it, and at £23.20 + vat for a new filler cap it *might* be a while before i replace it yet.. Share this post Link to post Share on other sites
jackherer 543 Posted September 11, 2008 Was that for me Miles? It isnt that the filter has broken up and ended up down the tower, when i rebuilt the engine i cleaned all the breathers out and the gauze filter looked a little worse for wear, so as an intermediate step i removed it as i didnt want any particles finding their way into the fresh engine. There is more of that gauze stuff under the filler neck. Share this post Link to post Share on other sites
Baz 421 Posted September 11, 2008 And it's all crap... get rid!! Share this post Link to post Share on other sites
philfingers 5 Posted September 11, 2008 My ducati gets milky in the oil level sight glass on short runs and it doesn't have any water in it anywhere (well apart from the battery) as it's oil cooled. given a long run it clears, but my pug never suffers from it! Share this post Link to post Share on other sites
Edp 67 3 Cars Posted September 12, 2008 My Mi does this. It gets really thick sometimes. I tend to give it a good thrash and that seems to clear most of it. So is the only way to stop it by having a oil filler on the cam cover? Share this post Link to post Share on other sites
SeanO'Connor 0 Posted September 13, 2008 Or go for a long run and get the engine warmed up properly, cars that are used mainly for shortr runs will suffer from this, as they are not getting warm enough to evaporate all the moisture from the engine. Share this post Link to post Share on other sites
Ethos 0 Posted November 15, 2008 I just cleaned out the breathers on my mi, they were really milky! Thing is gf just took it on a 30 minute drive... and I thrashed it last night Share this post Link to post Share on other sites
