Turbloide2 0 Posted September 7, 2008 Hi all i seam to have a problem. Got the engine and gearbox back in the car put driveshafts on put it in 1st gear to tighten the drivers side hub nut no problem, i then took it out of gear did a few other jobs went to tighten the pass side hub nut put it in 1st gear and i can still turn the wheel with no problem its turning the drivers side when i turn it and its going in all gears but cant seam to get it to engange into the engine so i can tighten the hub nut..... What could be the problem ive put new clutch and relsea bearing in also the car hasnt been ran yet and is still on axel stands.... Im a bit stumped to what is going off Hope some1 understand this cheers Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted September 7, 2008 It is called the differential and it is supposed to do this? Not sure quite how you have managed to tighten the drivers side hub nut mind you. Share this post Link to post Share on other sites
Turbloide2 0 Posted September 7, 2008 HI there the problem is that even with the car in 1st gear or any gear i can turn the wheels freely in the air With no resistance from the engine.......... Share this post Link to post Share on other sites
Turbloide2 0 Posted September 7, 2008 ahh i get what u mean now okiedokie cheers mate Share this post Link to post Share on other sites
