paul_portsmouth 3 Posted September 6, 2008 is there an easy way of doing it like the vw boys with camber shims Share this post Link to post Share on other sites
welshpug 1,677 Posted September 6, 2008 3 ways, 1) Source trailing arms with the suitable specifications. 2) Skip Brown camber adjustment kit (longer stub axles and an alloy plate to alter the angle) 3) Trailing arms modified to your spec, Martin, CRF450 does this at Bridgecraft engineering, http://forum.205gtidrivers.com/index.php?s...t=0&start=0 Share this post Link to post Share on other sites
paul_portsmouth 3 Posted September 6, 2008 the skip bronw kit sounds like an expensive camber shim kit Share this post Link to post Share on other sites
Baz 421 Posted September 8, 2008 As i said on msn, they're nothing like the VW's and can't be done that way. Easiest/cheapest is to change the trailing arms. Well, bar handbraking the car into a kerb each side then re-mounting the bent stub axle turned 180d... Share this post Link to post Share on other sites
