Powers
Peugeot Sport Bilstein Insert Dimensions Wanted
Powers
Does anyone have the dimensions of a Peugeot Sport Bilstein insert? Length of shaft, damper reservoir and total length.
Also the dimensions of a Bilstein body would be great also.
I will attach a picture later on for people to fully understand what dimensions I am after.
Cheers.
Spiky
anyone? :)
tom_m
Bilstein, maybe?
philfingers
Here you go
These are from a spare insert I have which i believe to be Tar
Bilstein 5103XDE60660t9
Bottom thread on the damper rod is M10 x 1.0
Top thread (top mount nut) is M14 x 1.5
Top spindle length is 58 x 14.36dia
Body is 312 x 40.00
Bottom rod is 198 x 10.96
http://s188.photobucket.com/albums/z143/oi...nt=IMG_8731.jpg
Edited by philfingers
Powers
Thanks Phil owe you one.
Also after dimensions of the body if anyone has any?
philfingers
can do tonight. I'm not sure what mine are whether they're PTS ones or not. The original set I had had the caps which went over the seals at the top of the body. I now have two sets, both purportedly PTS units but neither have the caps on the top of the bodies. Though they both look PTS other than that.
Will post some pics later and get you some dims too! Also the gravel inserts are longer I think.
Will whip them out and compare
Phil
Powers
Does anyone know where you can find out the specification of a Bilstein instert?
This is the product number 2906XDE 7880 M1 300 200
James Stewart
  Powers said:
"300 200"
Should imply 300/200 bump/rebound. Which I'm pretty sure is a 205 gravel insert (would have to double check on the rally car!).
James.
Powers
Thanks for the replies lads.
Genuine PTS bodies dont run 2 1/4" ID springs.
philfingers
pretty sure james is right, gravel spec
2.3" aren't they?
Phil
Powers
70mm ID Springs = PTS
tom_m
but you can get 2.5in plaforms from most places that stock the kits allowing you to use a wider (and cheaper) range of springs
