manrajf 0 Posted September 5, 2008 Hi i took my car upto sheffield today on the motorway and it was raining shed loads, when i got back home i lifted my passenger side floor mat and its absolutely drenched under there any ideas what it could be? cheers manraj Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted September 5, 2008 Does your interior fan work OK? Check the scuttle panel has the cover which goes over the heater fan box intake under the screen. See this topic or more info. When these are missing rain can run straight into the heater assembly from the scuttkle panel area & eventually leak trough into the passenger footwell. Other possibilities are a leaking door seal, windscreen seal or heater matrix. Best check you coolant level but the matrix usually leaks into the drivers footwell. http://forum.205gtidrivers.com/index.php?s...l=scuttle+panel Graham. Share this post Link to post Share on other sites
manrajf 0 Posted September 5, 2008 (edited) Does your interior fan work OK? Check the scuttle panel has the cover which goes over the heater fan box intake under the screen. See this topic or more info. When these are missing rain can run straight into the heater assembly from the scuttkle panel area & eventually leak trough into the passenger footwell. Other possibilities are a leaking door seal, windscreen seal or heater matrix. Best check you coolant level but the matrix usually leaks into the drivers footwell. http://forum.205gtidrivers.com/index.php?s...l=scuttle+panel Graham. cheers dude, the heater fan does work... once the rain stops i shall investigate the above. thanks Edited September 5, 2008 by manrajf Share this post Link to post Share on other sites
Rock Lobster 28 Posted September 5, 2008 had a similar problem on my old focus, a load of water in my passenger footwells, front and rear, it turned out to be a leaking windscreen on the top two corners, so i got some loctite clear silicone sealent and job done! Didn't get rid of the smell though! Share this post Link to post Share on other sites
dave_gti 0 Posted September 5, 2008 I was reading through all the history i had with my 205. and in the early nineties it developed a leak and was in and out of Peugeot, theyd replaced the windscreen seals, and all sorts, and it turned out they fixed it by removing and resealing the wing. . Thats my rant over, it made a good read when i was going through all the papers, was almost like a story book. Share this post Link to post Share on other sites
Jrod 7 Posted September 6, 2008 it made a good read when i was going through all the papers, was almost like a story book. You need to get out more! Share this post Link to post Share on other sites
