soap.mactavish
Gti6 Ecu Unlocking
soap.mactavish
just got my new gti6 engine box and ecu ready for the big swap.
but the bloke I got it off was thinking I wanted it for a 306 not a 205
so all i`ve only got the 4 digit pin needed to unlock it.
So what can I do??
can I plug it into a 306 with a pin pad to unlock it, then un plug it with the ignition on.
or send it off for £***`s to get it sorted
Alastairh
You need the code. Plug the ecu into a keypad 306 GTI'6, type the code in, start the car up (or power up), disconnect the ecu and job done.
The Keypad and ECU aren't matching pairs.
Alternatively, buy a pot of KY Jelly and phone the ECu Doctor etc...
Al
Edited by Alastairh
soap.mactavish
thanks
yes I have the code .
so let me get this right any keypaded 306 gti-6 will do?
but has it got to be a gti-6 or is there any other models that will do it?
Edited by soap.mactavish
Alastairh
Correct, any Keypad (normally phase 1) GTI6 will do. As for other models, i couldn't comment. Never tried it...
Al
jonnie205
so a keypad 306 gti6 will unlock any gti6 ecu? that is worth knowing
Peetypug
only if the ecu from a phase 1 and you have the code for it
pdd144c
Why not bypass the 12v output from the keypad directly to the ECU pin. Or in the case of fitting to a 205 just supply it with an ignition fed 12v. Never tried it but surely it would work?
You can send it to me if you have the code, I can test it and unlock it for the price of carriage
soap.mactavish
ok I`ll try and see if I can find a phase 1
I know a lad that tracks a gti6 but not sure on the year
thanks miles if I get stuck I`ll let you know . you could geting a pm off me saying "help me oby one your my only hope" lol
but thanks to you all
steve
jonnie205
why are you trying to see if you can find a phase 1 if miles has offered to do it for you for the price of carriage?
soap.mactavish
coz the lad that has a track 306 is a 100 yards away thats all
but I`m not sure on if its a phase 1 or not till I see him an ask
I am very gratfull that miles will do it if for me, if I cant do it on the 306 down the road.
